-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Scarey question (http://forums.pelicanparts.com/porsche-912-technical-forum/54751-scarey-question.html)
MikeP 12-19-2001 03:48 PM
Scarey question
Does any one know what a main bearing sounds like when it goes? I've got a loud high pitched screach that is scarey sounding. Could it be a bearing? It increases with rpms and goes away when there is an accelerating load on the engine. Any ideas????
adot 12-19-2001 04:07 PM
MikeP
maybe the generater fan is hitting the dog house. Or the generater bearings. I had the fan hitting the dog hse once, very scarey sound.
Brett
MikeP 12-19-2001 04:09 PM
Hi brett,
I thought that might be the problem and removed the fan belt and it didn't change a thing.
josh912 12-19-2001 04:14 PM
Might be something with the cluch and tranny, but a main bearing sounds more logical, Yikes!
Efrain68912 12-19-2001 04:31 PM
Throw out bearing, maybe?
Efrain
68 912 Coupe
MikeP 12-19-2001 04:34 PM
goosh i hope its only a throw out bearing. if it is it should change with the clutch. i'll check that. thanks
mike
adot 12-19-2001 05:21 PM
First, I have never heard/had a bad mains in a air cooled. I would think mains would have a loud lower sound than a 'loud high pitched screach '. Also, louder under ' accelerating load', not go away.
Think I will go with Efrain
Throw out bearing
Good Luck
Brett
MikeP 12-19-2001 06:10 PM
hmmm throwout bearing would be an easy fix!
Thanks guys I'll let ya know what I find.
Mike
