jknapp3's Avatar
1966 912 Ignition & Light Switch
I'm putting in a new complete harness. The headlight, and ignition switch are not an easy plug in for the aftermarket harness. The Ignition switch has two keys (copies) and no covers or such., The light switch is all intact.
I'm trying to get an idea as to what used ones are worth. I'll also have a 80% of a 66 harness. (Some has to be cut out) with fuse box, and all the under dash relays/flashers? Is there a demand for that too?
Old 11-22-2010, 11:27 AM
It's tedious but if you can get the harness out without cutting it will be more desirable. Replacement relays are available. The can flasher for the hazards is NLA but there is a VW part that works. These original relays/flashers are desired by those building concourse cars.
Old 11-23-2010, 03:36 PM
