-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Are These 912E Calipers? (http://forums.pelicanparts.com/porsche-912-technical-forum/573642-these-912e-calipers.html)
75-911S 11-05-2010 06:12 AM
I have a set of front brake calipers that I got with a bunch of other 912E spares I bought and I'd like to offer them For Sale to forum members but I want to make sure they are what I was told.
One one side the say: ATE on the left
P on the top
31 on the right of one
28 on the right of the other
On the other side they say: ATE P 72 on one
ATE P 67 on the other
Jack
http://forums.pelicanparts.com/uploa...1288962587.jpg
http://forums.pelicanparts.com/uploa...1288962641.jpg
http://forums.pelicanparts.com/uploa...1288962705.jpg
Matt Monson 11-05-2010 09:38 AM
I can't tell you from the numbers you posted, but 912e calipers are for non-vented rotors and it looks like if you pushed those pads back into place that spacing wouldn't be wide enough to fit a vented rotor through there. You will also want to measure the bolt spacing for mounting to the strut. In addition to 912e they could be early non-vented calipers from a SWB car. I know it's not a definitive answer, but hopefully it gets you moving in the right direction.
djpateman 11-05-2010 10:43 AM
Yes, I believe those are likely 912E rear calipers. Definitely rear calipers, and the lack of a spacer does indicate non-vented rotors. They could fit any rear non-vented rotors from 1968 or 1969 and later.
75-911S 11-05-2010 03:34 PM
Calipers
Thanks guys. I have another, bigger, set which must be for the front.
Jack
75-911S 11-08-2010 05:05 AM
912E Calipers
I cleaned up one of each for pix.
Were either of them alloy? these are definitely steel.
Jack
http://forums.pelicanparts.com/uploa...1289221409.jpg
http://forums.pelicanparts.com/uploa...1289221485.jpg
robfike 11-16-2010 04:30 AM
The 912E's all had steel calipers and non-vented rotors. Same as the early 911's. They seem to work very well for the weight of the 912E. I have had mine on track at Putnam Park, and Mid Ohio with no fade.
Rob
