Engine Vibration at 4k and above
My mechanic installed a new clutch disc and when I got the car back it had a vibration
at 4K and above. He did not installed a new pressure plate. What could he have done? Don __________________ 1965 912 1981 911SC 2006 Cayman S |
Don't drive it until you pull the motor and inspect.
He didn't mark the pressure plate so it was installed in a different position. The engine is now out of balance, unfortunately. The best solution for him to rectify with this mistake is to have the flywheel and clutch disk sent to a shop that understands how to balance these parts. I would recommend Jay's Precision or Competition Engineering in California. While it's apart, it would be wise lube the clutch release bearing and check the crankshaft free-play.
| All times are GMT -8. The time now is 12:19 PM. |
