GS GS is offline
Talking My 66 is finally running
Thanks for all your responses and help.
I put in hotter plugs (Bosch W7 ) and it finally cranked up. I also put on 44 IDF Webbers and a Header and it sounds great. I plan to run it for a while and pull the plugs to see if it's still running rich. If so, I may go to a W8 plug.
When I bought the car it was non running. It does have a big bore upgrade and I think it has a fairly high lift cam because of the 5 valve readjustments I had to make and the plug situation.
The God are smiling.
Old 01-27-2002, 05:17 AM
