-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   msd ignition and generators (http://forums.pelicanparts.com/porsche-912-technical-forum/585080-msd-ignition-generators.html)
lane912 01-12-2011 01:27 PM
ok if you have a generator on your car and you want to use a msd capacitive discharge ignition don't use the new type of regulator from Bosch!!!!!
just installed my generator after being rebuilt and also replaced the voltage regulator. then i ran down the street with it.
i got 2 miles then the generator melted, literally the leads from the commutator came un soldered and two bars from the com are missing.
the new type regulators do not regulate current!!!!
the msd ignition will draw as much current as it can
generator only rated for 25 amps!!!!
next thing is to go out to Emory's and get a alternator kit for my little beast
Jaems 01-12-2011 03:13 PM
http://forums.pelicanparts.com/uploa...1294873912.jpg
I would of done that first. Alternators is the only way to go, unless concurs
lane912 01-12-2011 04:40 PM
well hindsight being what it is i am picking up a alternator kit on monday from rod...
it looks like a good kit what are your thoughts of it?
Jaems 01-13-2011 11:46 AM
Rod's insulation is real clean. They did a very good job on the alternator stand. I just would not consider using a generator again on a non concurs car. However, they are a little on the spendy side.
cgarr 01-15-2011 07:58 PM
Was you regulator a 20 or 25 amp. The early generators were 20 amp and if you don't match the regulator it will toast your generator. I have been running a msd for 8 years now.
lane912 01-29-2011 10:32 PM
it was stamped 25a- dont know what i was drawing. i plan to throw a amp clamp on the output of the alternator to see whatthe draw realy is. upon further investigation i found that the published draw for the msd is 1A pe 1000rpm, that still puts me under the rating for the generator.
the alternator kit is working great now. i am now able to run higher wattage lamps in my headlights.
