68 door pocket repair
I've been searching the posts for a good solution to the 68 door pocket sag issue. Can anyone offer a step-by-step guide to fixing these things?
Donald T
'68 912 Coupe (current driver)
'68 911 Targa (workin' on it)
Old 05-10-2011, 06:52 AM
Brandon-FL's Avatar
I just replaced the elastic in both of my door pockets after considering this pretty nifty solution I had seen on 912bbs.org:
912 Board - Viewing Topic: 1968 door panel - pocket repair
If you search door pockets on the 912bbs you'll find a number of different "solutions."
912 Board - Search
Old 05-10-2011, 07:25 AM
That is a good way to go. You need to be able to pull the pockets back so that you can fasten the door arm hardware. The elastic will only degrade with use or age. I like this for a non-concourse 'solution'.
Donald T
Old 05-10-2011, 05:58 PM
