912 912 is offline
Porsche Crest Quarter Glass Seal
I finished chipping out the old brittle seal, but I am having a hard time getting the new seal in place. Does anyone know any good tricks to install the new seal?
Thanks for any help.
Old 04-25-2011, 10:39 AM
Are you using a OEM gasket? If you are. It should fit fairly easy with a little silicon spray for lubrication. If you are not using a OEM gasket, then good luck. You may have to do some trimming for it to fit.
Old 04-25-2011, 10:51 AM
912 912 is offline
Thanks for the input. I got the first seal done this weekend and will get the second one done later.
Old 05-02-2011, 08:56 AM
