Rear Swaybar for a 69 912?
Is it a big job to add a rear sway bar to a 912 that aint got one, I just added one to the front but I think the rear requires adding attachment points? and do you all think its worth it.
I thank you, but my wife does not!! Craig |
I just put a Weltmiester 19mm front bar on and am adding the rear soon. I have been told that the Weltmiester rear kit does not require any welding. The factory bar does. I am ordering a 19mm bar to match the front bar. The car pushes to much with just the front bar. Rear bar will balance this out nicely. I will report on the install on completion.
| All times are GMT -8. The time now is 10:17 PM. |
