-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   912e engine sheet metal question (http://forums.pelicanparts.com/porsche-912-technical-forum/615954-912e-engine-sheet-metal-question.html)
Papermaker 06-25-2011 02:54 PM
Hi--
At the rear of the driver's side engine sheet-metal there is a 13 mm hole and a 100 mm long slot. Can anyone tell me what the purpose of the hole and the slot is?
Thanks,
--Papermaker
TooBrash 06-25-2011 09:56 PM
It's very simple; some of the factory people got to test drive it, and the consensus following was that it deserved an exclamation point milled into the free area. {Pardon me, I only wanted to bother remembering my login info for the privilege of raving about how cool these are. The only thing I can compare it to is a helicopter, in which case I am a passenger not accorded any controls.}
WFBowen 06-26-2011 11:55 AM
Does it show in this photo?
http://forums.pelicanparts.com/uploa...1309114466.jpg
eki912 07-03-2011 01:24 AM
A picture, please?
That hole could be for the thermostat flap wire?
The slot.... Is it above the alternator? Or close to it ?for checking/adjusting the belt tension?
I simply don't remember anymore.... Haven't opened the the engine bay in my E for several years... No worries, haven't driven it either!
Papermaker 07-06-2011 03:28 AM
The hole and slot are not shown in FWBowen's picture. The hole could have been drilled in the sheet metal after manufacture. The slot runs along the car's longitudinal axis between the laterally stamped ribs and the fan shroud. It appears to have been stamped in during the manufacturing process. It has rolled edges and is square and perpendicular to other sheet metal features.
Can anyone help me add a picture? I've checked my Control Panel but I can't determine how to add photos or albums.
Thanks,
--John
Papermaker 07-11-2011 03:37 AM
Sheetmetal photo
Here is a photo of the hole and slot I"ve been asking questions about (I've used a couple of pieces of plastic to plug them).
http://forums.pelicanparts.com/uploa...1310378688.jpg
eki912 07-13-2011 12:15 PM
Could it be AC-compressor bracket hole?
I somehow recall it beeing somewhere around that area in my car, before I dumped the whole system....
Papermaker 07-14-2011 02:23 AM
Thanks for the observation. I've never seen an air conditioned 912e so I don't know what it looks like but the slot sure looks like it was done during the sheetmetal manufacturing process.
--John
eki912 07-14-2011 10:25 AM
Have a look at these pics, for example:
Http://912bbs.org/index.php?a=thread&p=146532
Sorry, dont know how to Copy the address.....writing on my sons IPad......
The red E, and picks from enginebay and AC compressor, and its bracket are right above your long slot.
WFBowen 07-14-2011 10:59 AM
I think Eki has it:
http://forums.pelicanparts.com/uploa...1310666332.jpg
eki912 07-14-2011 10:15 PM
Thats the one !
I remember taking it out, wasnt light one either....
Thanks for the perfect picture!SmileWavy
Papermaker 07-15-2011 04:11 AM
Ok guys, the air conditioning bracket makes sense to me.
Thanks for the help.
--John
Gratuitous photo of the car.
http://forums.pelicanparts.com/uploa...1310728140.jpg
eki912 07-15-2011 08:25 AM
A targa ????? :eek:
And E ??? :confused:
Originally 911, and engine changed ???
Papermaker 07-16-2011 04:57 AM
Yes, it is a '77 targa with 912e running gear, 2.0 L engine and D-jet FI. The P.O. couldn't afford to rebuild the magnesium case 2.7 L so the car sat for a long time while he tried to put a type IV engine in it. I picked it up and went through the whole car while installing the 912e parts.
Here is a photo that you won’t see everyday. A 2.0 L. engine with a D-jet in a ’77 targa body.
--John
http://forums.pelicanparts.com/uploa...1310817214.jpg
