Replace Tach with 911 Tach
Hello all:
I have run a search on this subject but came up with nothing; both here and the 912BBS. Has anyone replaced their 912 tach with a 911 tach without sending it out for recalibration? Were you able to use a progamable in-line tach module to convert the signal for the 911 6 cylinder tach? I did read were someone had taken a tach that is adjustable (4-6-8 cyl) and replaced the guts of the 911 tach with it. Thanks for you hep, Jace |
| All times are GMT -8. The time now is 02:54 PM. |
