No Substitutes
912 brake, turn elec.
Help, high and low beams work and parking lights. Turn signals and brake lights do not. I checked fuses OK, checked bulbs OK Is it the relay?
Old 11-29-2011, 02:44 PM
C. Clark's Avatar
The 69 has a turn signal relay I think. Check the grounds, they are notorious.
Thank you, Your Welcome! and Best of Luck....
Chas.
356912911
Old 11-29-2011, 03:11 PM
No Substitutes
Thanks it's a '68 ? A shop in the bay area that could do a electrical check would be helpful.
Old 11-30-2011, 10:28 AM
Like Clark has said. You need to clean all the grounds and connections first. You could be wasting money. If you haven't.
Old 11-30-2011, 01:59 PM
The brake Lts. Come off the brake switch on the master cyclinder.
Old 12-07-2011, 09:15 PM
