Question Flywheel
I see in the shop manual that the flywheels are balanced with the crank at the factory. SO, if you need to replace a flywheel does that screw up the balance of the engine?
Old 04-06-2002, 10:35 PM
If you want to do it right, you balance the flywheel andcrank together. But, if your crank is balanced, and your flywheel is balanced, you shouldn't have a problem.
Old 04-07-2002, 01:12 PM
