I need to know if I can put a 215mm (69) clutch, pressure plate and flywheel into a 1968 912? Anyone have any experance with this one?
I put the 215mm 911T pressure plate and clutch disc on my 912. Works great until the flywheel seal leaks all over it. Change it while you're down there.
Efrain 68 912 Coupe 62 A-H Sprite (VARA DP) 97 Van Diemen FC 94 Mazda RX-7 |
