diz plaz is cwazy
MSD / Mallory IGNITION WIREING.
Hi Folks, My 912 will not start with my Mallory CDI installed. I get spark when I test as per manual but engine will not start. I think my problem is the small red wire that needs 12V switched. I am using a Pertronix Ignitor and have wired as follows:
Big Red to Starter Positive + Big Black to Ground Big Orange to Coil + Small Black to Coil - Small Red to red wire that was on the coil from ignition Red Pertronix Wire to Thin Purple Black Pertronix Wire to Thin Green Question. The small 12V switched Red Wire connects to the ignition red from car. Do these go on + Igniton coil or where? it seems I need to close this circuit for engine to start. Thanks for any input. Riq P.S Both MSD and Mallory CDI have identical color wiring and connections.
Life rewards action, He who is not afraid is safe! A Zest for living requires a willingness to die! -------------------------------------------------------- BWM R1100S 2004 (fat girl) BMW S1000RR 2011(skinny BMW R1200S 2007 (stingger) Honda CX500TC 1982 (turbo) |
