912 oil cooler
![]() 5:04 - as requested, here is a pic of my improv 911 a/c condensor now doing time as 912 external oil cooler with fans. Since it's made to fit right in that very spot, it's perfectly contoured and only requires x2 very small holes and the center bracket to mount. I used Aeroquip AN -8 lines for all the oil lines. engin now holds nearly 8 quarts of oil between the accup-sump, HP-1 filter, 2 oil coolers (the other is behind the shroud) and lines. Let me know if you have any other questions. Brgds, PEter
Brgds, Peter Baldauf 1967 912 1988 911 vert 944 TS 1969 911 E 1956 356 Conti 1983 911 SC |
Peter,
That looks impressive, did you do the design and retro fit yourself. Would you be willing to share your idea for other 912 owners to try? Cheers, Trevor |
Very impressive what kind of driving are you doing that would require such a system?
Jerry McAbee 67 912 Lucy 02 Tundra 4x4 |
