brake light
My 68 912 has an intermittant brake light on the driver's side that won'y stay working. Every thing looks clean and fits tight and works for a few stops and then quits. Any help will be appreciated. Thanks!
Old 06-01-2012, 12:26 PM
Grounds.
It's always the grounds.
Scott
'78 SC mit Sportomatic - Sold
Old 06-01-2012, 07:03 PM
C. Clark's Avatar
Ground connection issue or positive voltage connection issue.... I hate intermittent stuff!
Thank you, Your Welcome! and Best of Luck....
Chas.
356912911
Old 06-01-2012, 09:18 PM
Otto H. Wegkamp
Guest
Posts: n/a
If all the other lights (rear light, turn signal, backup) in the unit have the same problem, its likely a bad ground. If only the brake light intermits, check the lamp fitting. Clean the contact surfaces with some fine steel wool.
Otto
Old 06-07-2012, 07:57 AM
