Question steering removal 1976 912e????
How do I remove the horn bar to get at steering wheel nut?
Thanks Steve
Old 05-14-2002, 03:32 PM
WFBowen's Avatar
Steve:
If it's a stock setup, there are round press-fit connectors inside of each corner of the plastic horn piece. Carefully pry each corner straight out - you might want to work it out slowly as the plastic can be brittle with age.
Old 05-14-2002, 08:18 PM
steering %^^*&*^wheel removal
Thanks wf bowen
Old 05-14-2002, 08:38 PM
