willbur's Avatar
Anyone ever put a 915 tranny in a SWB 912?
I am seeking help from anyone who has seen or done this swap before. SWB 912 915 transaxle in place of the 901 that they came with...
Wil.
Old 05-13-2002, 03:02 PM
willbur's Avatar
Anyone?
Wil.
Old 05-15-2002, 12:22 AM
912s's Avatar
You could try "JordanJames" if he's still around? Although he also changed his car to a LWB when he did the V8 & 915 swap and has since sold the car...
See this post for more info - Renegade Hybrids
Scot
'67 912
'69 Bug
Old 05-15-2002, 04:09 AM
willbur's Avatar
Thank you... website was a dead end... E-mailed JJ...
Wil.
Old 05-15-2002, 07:03 AM
Senior Member
Hello
Trany will bolt up.
The front cone is close to the hump between the seats so you have to clear that area with a hammer or shim the tranycarrier around 1/4" so the trany sits lower.
Other point is the drive shaft setup.
You can manage to mix late 6 bolt ( sportomatic ) drive shafts onto your old outher cv joints.
Grüsse
Old 05-18-2002, 02:36 AM
willbur's Avatar
Perfect 90% of the tools I own are HAMMERS... ummm please explain "mix"... they will bolt up/interchange or are we talking some kind of surgery?
Thanks for the response...
Old 05-18-2002, 09:09 PM
Senior Member
Hello
You are a hammersmith ?
Basically the problem is to find matching CV joints.
The pre 78 915 tranys have the 462 bolt pattern using 4 M10 hex screws the later units have the 6 bolt pattern ( using M8 screws ) like yor old trany uses too. Now those CV joints are a that bigger in diameter.....
But the 925 ( Sportomatic ) used the smaller CV´s in the first years ( I think 74-77 )
Matching the rifght parts is the trick.
Grüsse
Old 05-21-2002, 06:22 PM
willbur's Avatar
not a hammersmith just a aerospace guy (ex R.A.M.S.) you know measure with micrometer mark with chalk cut with chainsaw... i need to do more hands on research huh? thanks for the help Roland...
Wil.
Wil D
______________________
47 Plymouth P-15 / 55 Willys 6-226 / 64 Dodge Dart / 65 Porsche 9series / 68 Porsche 9series / 69 Dodge Charger /67 VW SoCal look
Old 05-21-2002, 11:08 PM
