'67 CV's don't bolt to '69 901 Tranny- HELP!
Yesterday-
I rolled under, with fresh packed Cv's out of the '67 912 I rescued, and felt that "blue" feeling when I tried to install too small CV's to the Diff hubs of the '69 901 5-speed. On the passenger side of the Tranny is a stub and 5 bolt holes. The driver side has zero stub and 6 holes.. Q! Do I need to aquire '69 inner CV's? Will they slot on my '67 axels? WWUDo? Doc Portland,Or
-=Doc=- *P-land |
I am a little confused Doc.
Do you have a 69 car with large hubs inner and outer? If you do you need to find some other axles. If you have small hubs on the trailing arms, you need to find two early hubs for the trans. Then everything matches. Let me know.....JMB
68' 912/5 modified brakes, suspension, limited slip trans, hi-performance engine. 67' 912/5 racecar project |
*I guess I didn't fully comunicate I have a '67 912 that I am installing a '69 5 speed in.. and own the small early '67 axels and inner and outer CV joints- I was surprised to find they did not bolt to the '69's 901 tranny output flanges.. I assume- if I aquire '69 Cv's for the inner pair they will replace the early small ones I have now, and everything work fine, agree? PS- *Where does on go to beat the $150.00 price for each '69 Cv? Doc Portland,Or
-=Doc=- *P-land |
Doc,I have a 1967 which I put a 1971 5spd in and had the same problem.All you have to do is remove the flanges from the trans(1 bolt in the middle) and swap them out with the smaller flange from some donor trans,perhaps your old one.They have the same diameter at the gear box,just different dia.at the CV.Worked for me just fine.Hope this helps
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS Last edited by Steve F; 06-03-2002 at 02:45 PM.. |
