Fuel Pump - New or Rebuild it ?
How much luck have you all had with rebuilding the stock pump?
I know its easy, but I dont want to rebuild it again in 6 months. Someof these 30 year old parts can only take so many rebuilds.
New$130
Rebuild$30
Brett
Old 06-11-2002, 06:08 PM
Rebuild it........
If it lasts 6 months it cost you $5/month to find out, pretty cheap investment overall.
Craig
69-912
Old 06-11-2002, 06:56 PM
abit off center
cgarr's Avatar
Take it apart and see whats wrong, if its just a leaking diaphram its an easy one, mine had the check valve come apart inside and I had to re-spike the plate. Make sure the mating surfaces are not warped, mine were and had to be surfaced on a flat block. I guess mine was in really bad shape. If you go with new Ill take your core!!!!
Craig
Old 06-11-2002, 07:15 PM
wwwcad's Avatar
If it doesn't run or crawl away, grab it and rebuild it!!
Bill
Old 06-11-2002, 07:34 PM
Duke's Avatar
Porsche Crest
As long as the check valves are ok you can rebuild it. If the check valves are defective you need a new fuel pump. Duke, 69 912.
Old 06-12-2002, 08:46 AM
