'76 912E parts question?!
When I take my flywheel off do I need to get new bolts? If so where? Also I do need to replace the metal shim right? Where can I get this? I have checked PP but they do not list these in their catalogs..thanks
Try this link
http://www.pelicanparts.com/catalog/shopcart/9144/por_9144_clutch_main.htm You also want to replace the pilot bearing on the flywheel and the rear main oil seal in the motor. When you have it apart replace every thing that you can. |
| All times are GMT -8. The time now is 06:25 AM. |
