Peter T.'s Avatar
Oil Leak?
Just rolled the Porsche out of the garage where she's sat for the past several months when I noticed some oil spillage on the floor from where the front of the car had been sitting.
I can understand if there's an oil leak at the rear of the car, but what might cause a leak in the front?
Maybe a cooler line? But I haven't noticed that there is one there...
Any suggestions?
Old 12-25-2012, 04:01 PM
Could it be brake fluid from the master cylinder? Pull up your drivers mat and remove the pedal board. The other option is to remove the cover on the linkage coupler and see if your tunnel is dry.
Old 12-25-2012, 07:22 PM
