pointless ignition
Hello,
Does anyone know if a Pertronix pointless ignition system, be used in conjunction with a permatune CDI setup? Thank you, Chas. 69/912 |
reply
Hello,
Since I recieved no relpies I'm assuming no one knew the answer. I e-mailed Perma-tune and was advised as follows... "Yes, you can use the Pertronix. Connect the red wire of the Pertronix to the violet wire of the 911e box and the black wire of the Pertronix to the yellow wire of the Perma-Tune." Set the ignition timing to stock specs. |
| All times are GMT -8. The time now is 03:15 PM. |
