1987 Black Targa
Rainking's Avatar
912 Maximum Horsepower?
All,
Kind of a newbie to engines and restoration. I am looking at a car and it has a 912 engine in it. I have been searching to see what is the maximum reasonable horsepower I can get out of the 912 engine. Heard of big bore kits, etc but wanted some input.
Thanks!
Rainking
1987 Black on Black Targa
"Honestly now, did you spend your youth dreaming about someday owning a Nissan or a Mitsubishi?"
Old 01-21-2013, 09:30 PM
Cajundaddy's Avatar
Did you want to stay with the same block? A little creativity and you could stuff a 450hp LS3 V8 in there... or a 3.6L 964 motor. The only limitations are your imagination and bank account. If you want to stick with the 4cyl, Lloyd Mosier can set you up. He has a shop near me and I believe he holds the world record 1/4 mile with a 2.0L VW motor. 600hp??
http://www.littlegiantkiller.com/index.htm
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 01-21-2013, 09:48 PM
1987 Black Targa
Rainking's Avatar
Have done the 911 engine and want to stick with the same block. Budget is limited so...
Rainking
Old 01-21-2013, 09:59 PM
Cajundaddy's Avatar
Budget, NA/FI, fuel choice, longevity, all matter when choosing a performance envelope for your build. Lloyds 2.0L Ghia motor is good for 149 rwhp so that is probably a good target for a street NA motor.
Old 01-21-2013, 11:13 PM
A 616 motor with an 86mm big bore kit along with the correct camshaft should yield around 130 HP. If built correctly, the increase in power will not affect longevity. A full flow oil filter is recommended as part of the build. More information can be found on the 912 BBS
Peter
Old 01-22-2013, 08:53 AM
