Just double checking,I have the 022(no-vac) stock distributor,and weber 40 IDF's.Should timing ,with a light be at 3 BTDC at 700/800 rpms to be the most efficient?
Thanks,Steve
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
I'm not familar with the .022 dist. but the .050's are timed at 4 to 5 degrees BTDC, my thinking would be 3 degrees BTDC as you mention would be safe. The problem here is overheating, wrong timing can overheat air cooled engines to the point they fry a piston, so watch your heat guage and stay out of the red zone.
Good luck, Chas. |
