drain hole location
Still not sure where the small tube comes out in the front pan. Is is in the middle? or some where else.. a picture of the underneath of the pan where it come out would be of great help. I don't have any hols in my front pan except for the middle..
dave |
Sorry this was supposed to be under the black box under the dash discussion. The small tube after the "Y" to the front of the car. Where does it come out?
dave |
Senior Member
Hello
On 69-73 ROW the tube goes forward into a hole beside the battery post and then trough the forward crossmember support showing some 0,5" out from the underbelly. Grüsse |
Dave:
On my 69 there are two holes in the front nose pan. The right side one has the hose from the fuel vapor cannister going out of it. The left hole has a rubber hose piece which I believe is just a drain hose should the trunk flood. The holes are about 24" to 30"apart and about a foot in from the front. Maybe someone has the exact measurements and hole diameter. Ron
RonD 69912T |
Not to be a pain.. but is there anyone who could snap a pic of the area so I can get it just right?
dave |
