Porsche Crest WTB 1969 912 Hazard Switch
I need to buy a 912 hazard switch for a 1969 coupe.
Alternately, I am also interested in any work around solutions anyone has tried that work to get my turn signals to work without having to route through the hazards as they are designed to be.
Thanks.
Old 12-14-2013, 04:36 PM
pors1968's Avatar
For your switch try forum parts wanted and it one year swicth good luck
Old 12-15-2013, 12:31 PM
Otto H. Wegkamp
Guest
Posts: n/a
Are you sure the hazard circuit - wiring, switch and relay - is faulty. It would not be the first time that just the hazard fuse is blown. It's a seperate in-wire fuse holder, located near the fuse box. The hazard switch is a quite simple switch and not often the cause of a failing hazard circuit. The hazard relay is a more or less sensitive component and therefore also important to look at.
To help you, we need more info regarding functionality of other parts of the electric circuit - what is functional and what not.
Otto
Old 12-17-2013, 03:06 PM
Thanks to pors1968 and Otto H. Wegkamp for your help. I will consult with my mechanic to ensure the switch is the problem, or hopefully to determine that it is not.
Old 12-24-2013, 02:35 PM
