Crank Pulley and Generator pulley
My Crank pulley and generator pulley are out of alignment which is creating a throw off problem with belt. Has anyone had this problem. It is racking my brain!!! The Generator pulley is out farther than the crank pulley. I tried a new backing plate but generator holes are not the same. The generator is not new. I did not note this when I started my project. I'm assuming that it was like that when I started. the only thing that has changed is a new Skat Crank. I measured that and it is the same as my old crank. pulleys are installed correctly as they can only go on one way. backing plate only goes on one way.. I am lost. anyone else had this problem???
Old 01-12-2014, 03:26 PM
Pulley Problem
More likely than not, the pulley halves on the generator or on backwards. pull them off, turn them around and see it that works. I had that issue when I bought my 912. Thought it was the wrong generator, etc. Easy fix.
Ed T
Old 01-12-2014, 06:24 PM
been there done that not the problem but thanks. Wishing it was that easy.
Old 01-13-2014, 08:17 AM
Pictures can sometimes help with a problem.
Did the fan bolt on OK, and can turn freely without rubbing? Is the fan on backwards? Is the back of the generator flush with the Air/fan housing (dog House) front plate? Is the Dog house on correctly? Is it the right Generator?
Sometimes it is hard to diagnose a problem without seeing it.
Old 01-13-2014, 09:35 AM
Ok here are some photos. the first picture is before I took the engine apart for rebuild. the others are after the rebuild trying to complete it. it looks like it was this way before I started. the only thing I can come up with is the generator is wrong size. Hope you see what I don't see.
Thanks for the help.
Spencer
Old 01-13-2014, 12:44 PM
Hi Spencer,
Just took a look at my '68 and the backing plate is on the other way. It's recessed into the dog house rather than the way yours looks in the last picture.
Tony
Tony
1973 914 2.2 FAT Black
1974 911 Targa Lime Green
2018 Macan GTS White
2019 Targa GTS Agate Grey
Old 01-13-2014, 01:59 PM
Yeah, I thought that was the problem too after looking at a 356.. I went and bought the different backing plate and the mounting holes are too narrow. I'm beginning to believe that I have the wrong generator. it is a GR15X. It measures 6 3/4 inches from front to back and 10 inches total end of bolt to end of bolt..
Thanks though
Old 01-13-2014, 02:30 PM
Tony I think you are right I have found out that the generator had been changed out sometime ago. Upgraded to a bigger generator. the backing plate is suppose to be for a 69 912. and we now believe that I have a VW back plate. Now I just need to find the right plate and I think my problem is solved.
thanks again
Spencer.
Old 01-13-2014, 03:00 PM
jittsl's Avatar
I may have an old generator with the right part. I'll let you know tommorow.
Laurence
1998 Specbox racer / 1998 Boxster / 1984 RSR tribute
1970 911E Coupe / 1970 911E "speedster" / 1969 912 Targa
1963 356B T6 Coupe / 1962 356B T6 Cabriolet
Current projects - 1955 356 pre-a Speedster / 1964 356C
Old 01-13-2014, 05:39 PM
WFBowen's Avatar
The two generators use different mounting parts all of which "fit", but can result in the wrong clearances.
Some of the parts that are different are: Rear mounting nut (towards front of car); Carrier plate; Fan; cover plate and fan hub. I did a similar conversion a few years ago and laid out all of the parts from both cars, hoping to choose those in the best condition, when I realized just how different (even slightly) the setups are.
Here's a photo posted by member djdsc several years ago when we both posted on a similar situation.
Old 01-13-2014, 08:44 PM
The early engines will have a smaller generator and a smaller generator stand. If the early Generator has been replaced with a larger one then the stand was probably replaced. You will have to stay with a larger generator, the one for the 69 912.
The first picture is a backing plate for a small generator. The second in a picture of a large generator.
Old 01-14-2014, 09:18 AM
WFBowen it is the picture on the right that I need. and to Jaems the bottom pic. Just found out that it is the 1969 set up that I am looking for. I can find a new back plate but I believe there are three pieces. anyone have a pic of the third piece. I have the small ring. I can get that part I have in the pic. And I know there is a paper gasket. Is the fan different and is the set up two or three pieces? I actually think I have the correct fan by looking at WF picture.
Old 01-14-2014, 11:33 AM
WFBowen's Avatar
49 900.028.008.01 Spring Washer. B 6 DIN 137 bost.
50 900.075.010.02 Hexagon Srew M 6x12 DIN 933-8G
52 616.106.181.00 Nut for fan for generator 350 W
(52) 547.09.303 Nut for fan for generator 420 W
53 616.106.011.00 Fan for generator 350 W
(53) 616.106.023.00 Fan for generator 420 W
54 546.06.204 Cover plate for generator 350 W
(54) 616.106.337.00 Cover plate for generator 420 W
55 546.06.202 Washer
56 546.06.203 Carrier plate for generator 350 W
57 539.09.314 Washer
58 539.06.201 Hub for fan for generator 350 W
(58) 616.106.201.00 Hub for fan for generator 420 W
59 539.06.102 Reinforcement flange for generator 350 W
(59) 616.106.339.00 Reinforcement flange for fan cover for generator 350 W
616.106.115.00 Cover plate for generator 420 W
60 616.106.125.00 Distance ring
61 616.106.105.01 Cover for fan housing, generator 350 W
(61) 616.106.024.00 Cover for fan housing, generator 420 W
Old 01-14-2014, 02:44 PM
jittsl's Avatar
Sorry. Can't help with that piece. Thought I may have a spare used generator but I know I don't have the fan system spare.
Laurence
Old 01-14-2014, 07:24 PM
The number 61 is for the GR 26x generator 90 mm. Mine was converted some time ago to the larger GR15x larger diameter. I did find the back plate I think. Thanks for all the help we will some how get to the bottom of this problem.
Spencer
Old 01-14-2014, 08:26 PM
#61 pictured is for the early small generator.
Old 01-15-2014, 09:28 AM
