Renewing rivets for the rear grille (?)
Hi! In order to restore the rear grille, I have to sacrifice the original rivets (photo). What will the best substitute be? B.r.
Old 03-31-2014, 03:54 AM
Can anybody help me with this problem? B.r.
Old 04-02-2014, 12:42 PM
Bob Harriman's Avatar
Regular rivets would not look good. Go onto the ESR technical thread. They will know. World of quality knowledge over there.
Technical Info
Just don't mention it's a 912. Some of them take to long to respond otherwise.
Also, do a search. It's been discussed many times.
Bob
Old 04-02-2014, 03:17 PM
Try here also.
Porsche 911 Technical Forum - Pelican Parts Technical BBS
Remember, that is the exact same piece that's on the 911's.
Bob
Old 04-02-2014, 03:21 PM
OK Bob....thanks for the advices. B.r.
Old 04-03-2014, 06:59 AM
WFBowen's Avatar
This might be a starting point:
McMaster-Carr
& scroll down to 'Low-Profile Flat Head Solid Rivets'
Old 04-03-2014, 09:35 AM
Yes - I think this may be the solution. Thanks!
Old 04-03-2014, 02:31 PM
Tinners rivets are too hard to work; go with the AL ones that are much softer. I used MC AL rivets to rework my turn signal housings before installing new lenses. I tried to use the tinners rivets first and gave up, even with the correct rivet buck. I attached reflectors and one ground lug. You may have to rework the heads to make them look correct
Peter
Old 04-03-2014, 05:30 PM
Peter, thanks for your suggestions - what a "fight"
Old 04-05-2014, 04:23 AM
