help me find rear caliper rebuild kit
I've got a 67 912 and need to rebuild the rear brakes. i purchased the kit that pelican recommends and it is not the right one. the square seals are too big and the rubber boot is too small?
i ordered part # 901-352-964-11-M4
the calipers i have look like the god ones in this picture. from cmpski.
the old rubber boots had some numbers on them if that helps?
13.8102-3001.1 and 44473 3-12
any help would be appreciated
i must have the right kit but the square seal is super tight compared to the old ones. i got the calipers together using the old seals.
67 912s 2.0L MFI Frankenstein
Money green
71 911t Metalic Blue
http://www.cardomain.com/ride/2342860
Old 05-21-2014, 01:14 PM
You might try contacting Eric at PMB Performance; I know he'll rebuild your calipers but he might sell a rebuild kit too.
Peter
Old 05-22-2014, 05:25 AM
Your photo is of 911S vented brake calipers for LWB cars. The spacing for the front and rears are different on your '67 as well a many other differences as to piston diameter and disk thickness.
The stock rears were the same from '65-'68 unless you actually have the S rears for vented disks. If that is the case they are a rare bird as they only appeared on the '67-'68 911S and the '68 911L.
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 05-22-2014, 08:33 AM
