-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Weird fast idle problem? Urgent! (http://forums.pelicanparts.com/porsche-912-technical-forum/831804-weird-fast-idle-problem-urgent.html)
Jaems 10-02-2014 09:03 AM
Hi Scott,
Now that you sold the SC, are you looking for another 12?
Catalyst07 10-02-2014 03:20 PM
Haha, thanks guys - how far should the arm be able to rotate ? Mine moves about 2mm and snaps back.
Also, my breaker point gap appears to be 0 unless I'm looking at the wrong thing.
JT912 10-02-2014 03:27 PM
It doesn't move much. I'd venture to say if you are getting some movement and it snaps back you are fine. Just put a couple drops on the pad and check that the distributor is tight. Point gap will be zero unless it is on the lobe of the shaft. If you turn over the engine by hand, you should see the gap open.
Catalyst07 10-05-2014 06:47 PM
Lubed distributor arm with 2 drops, as per my pellows book - no change in idle.
Any other ideas?
JT912 10-05-2014 07:18 PM
Have you disconnected the linkage from the carbs and then started the car to see if your idle problem exists?
Where are you located?
Catalyst07 10-05-2014 08:15 PM
Yes - I've never experienced a problem this mysterious before - these cars are relatively simple.
I'm in Palo Alto, CA.
