Brake Upgrade
Hey guys,
I am starting to research brake upgrades for my 1969 912. What upgrades have you completed on your rides? Here is some car data: 1969 912 Targa 14" wheels Brakes are stock 19mm Master-cylinder 2.4FAT engine conversion Thanks, Russ |
Wicht front strut do you have.With koni or bilstein 3.5 you can have S brake or carera caliper.
Curiosity; What kind of upgrade are you looking for? Restoration or performance? The factory setup is more than adequate for the 912 as it is identical to the 911.
911 Brake Products and Accessories I did all my caliper restoration with Eric. http://i1296.photobucket.com/albums/...psd33c16aa.jpg http://i1296.photobucket.com/albums/...pse28ea765.jpg http://i1296.photobucket.com/albums/...ps971d2029.jpg |
Hey Bob,
Thanks for the reply and suggestions. After reading through some reviews and doing some more research I believe that you are correct. The stock arrangement should be satisfactory. From experience with my 914braking I too believe that the original setup should work fine. So I am now leaning towards cleaning and renewing. I actually just got the car back on the road after a year in restoration and really have not giving the brakes any attention...as a matter of fact they still have the old rotors and pads that came on the car. The calibers that you have pictured really looks like the BMW upgrade I completed on my 914 many years ago. They worked great! Thanks again for the suggestion and link to PMB. Russ |
You can also go to the vented rotor system.
| All times are GMT -8. The time now is 11:19 AM. |
