031 distributor timing
Hello,
Can some one tell me what is the static timing on a 031 distributor for my 68 912? And also, what is the dynamic timing for the same? Thanks Bao |
The same as the original 022.
3 degrees BTDC static 5-14 degrees at 1000 rpm 13-18 degrees at 1250 rpm 21-26 degrees at 2000 rpm 29-34 degrees at 3000 rpm 30-35 degrees at 3100 rpm Hopefully the 031 is one of the type 1 or 2 and not the third type that is not made in Germany. |
Thanks for the info. I do have a type 1 distributor and was clean and rebuilt by Glenn Ring.
| All times are GMT -8. The time now is 01:55 PM. |
