-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Is this where the oil plug is installed? (http://forums.pelicanparts.com/porsche-912-technical-forum/85151-where-oil-plug-installed.html)
cgarr 10-23-2002 03:24 PM
1 Attachment(s)
Is this where they plug the oil pump outlet when changing to a full flow filtering system? Is the hole just tapped and plugged? What size pipe tap is used?
Craig
Roland Kunz 10-25-2002 05:34 PM
Hello
Yep thats it. AFIR use a DIN 910 plug size was 14 x1,5 or 16 x 1,5.
You have to drill up and off center.
Grüsse
