Window cranks - which is correct? Year specific?
After much research, I am stumped and left with no answers.
Which window cranks are correct per year or years? I've found several conflicting sources & would like to know before I look to replace my mismatched set. Thanks! Which is correct for a 1968 912? Both? http://www.pelicanparts.com/catalog/...FS54247020.jpg http://cdn.shopify.com/s/files/1/011...G?v=1405352477 |
lower picture is correct for '68.
Tony |
Top one is a '66.
thanks guys!
So to reiterate: The top one is '65-'67. lower pic is '68 only? '69 is? |
There is a version of the top crank which has a plastic insert on the hole. I think it is a '67 crank.
The top is a 65-66 and the 67 is like the 65-66, with also another plastic insert in the handle. The 69 is like the 68.
Dr. Johnson book: "The 911 and 912 Porsche" (a restorer's guide to authenticity) will help you in some of this. |
thanks! |
| All times are GMT -8. The time now is 09:56 AM. |
