Compression test question for potential 912 purchase
I'm looking at a car that has the following compression numbers:
1) 145psi 2)140psi 3)120psi and 4) 150psi #3 is 10% lower than the others. Is this a problem? I was told this could be the potential problem- "The cooling air to #3cylinder is blocked by the oil cooler so it tends to run hotter and as a result it tends to wear faster than the other cylinders." Any help is much appreciated. Thanks |
| All times are GMT -8. The time now is 09:16 AM. |
