Distributor clamp
While testing the fit of my new distributor cap before unplugging any wires on the old cap I noticed that the distributor moved (rotated) slightly. I reset the timing and tightened the distributor clamp as tight as I could but I don't think I trust it. The clamp is a flimsy stamped part . I would like to replace the clamp with a stronger one but can't locate one for an 050 that is any better than the one I have.
The only fix I can think of would be to remove some metal between the clamp ears so the bolt can compress it more and tighter.
Any suggestions??
Thanks,
Ron
RonD 69912T
Old 11-13-2002, 06:20 AM
Hey Ron
Just remove some metal. No cost, just time
GoodLuck
Old 11-13-2002, 06:24 AM
