Oil Temp sensor
I have problems with my oil temp system. The black and green wire is disconnected from the back of the gage, but there are no free terminals to connect it to. I assume that the gage is connected up wrong. Does anybody have any idea which terminal it should go to?
At the other end of the system I cannot locate the temp sensor fitting. I have an oil pressure sender behind the distributor with a single green wire which turns off the green idiot light when I disconnect it. Is this a dual purpose sender? Any enlightenment will be appreciated. Danke..........Ron |
On my 69 I have a oil pressure switch & oil temp sender located right next to it. Not sure about the color of the wires on the dash gauge though.
Look at this thread
gauge wires The green/black is there in the pix. Maybe this will help GoodLuck Brett |
Little More Info
Do you see the black/green or the green/black black/green= right turn sig Green/black= pressure unit. Straight shot,gauge to unit GoodLuck Brett |
Hope this helps.
You can see the green and black wire on the temp guage. You can also see the blue/yellow and also the brown earths. Alan.UK
