Throw Out Bearing
As I get my 69 ready for winter storage I noticed the throw out bearing is starting to "sing" to me. Probably from lack of use on a week end driver.
Planning ahead for next spring to replace the clutch plate, pressure plate and throw out bearing what about the gland nut (Pilot Bearing) in the flywheel?? Are there roller bearing types availiable for our cars? What's the recommendation?
I am hoping the flywheel can be cleaned up, not replaced. If not a new ring gear too unless it's part of the flywheel.
Where is the best place to buy a stock clutch and how much will it cost??
Thanks,
Ron
RonD 69912T
Old 11-13-2002, 01:25 PM
Storage !!!
912's hate that
First, Pelican has a great price on the cluch plate 130. Ebay for the disk 60 + or - 15.. Bearing, not sure
Ring gear is part of the flywheel,but can be cleaned up with a file, so I here. Flywheel at Stoddards=230.
Whats with that storage thing, drive it
Brett
Old 11-13-2002, 05:11 PM
Brett:
Were talking about Chicago winters here. The car is lucky to be in storage during our winter, I wish I was!
Thanks for the info,
Ron
RonD 69912T
Old 11-14-2002, 05:54 AM
Ron,
How far are you from Des Plaines?? I will be out there for a few days in either late December or mid-January. Always nice to meet 912 owners!
Craig
Old 11-14-2002, 07:27 AM
Craig:
You will be approx 10 miles or less away depending where you are staying in Des Plaines. Give me a call when you arrive and we will set up a date to meet here at my plant so you can see my car.
1-800-323-1653 x613
Powernail Co.
Ron D
RonD 69912T
Old 11-14-2002, 10:35 AM
Ron,
I'll know in a week or so when I will be out that way.
Craig
Old 11-14-2002, 11:54 AM
Green 912's Avatar
Thumbs up
Replace the stock gland nut as they are one use only. When they fail you have a big, gotta split the case, me$$. Scat make a nice gland nut ($50)with a good bearing installed and it will take well over 400ft/lbs. The nut is stronger that the stock crank.
Old 11-14-2002, 01:46 PM
