912 trans in a 911 ?
I have a 68 912 transmission I would like to put in a 69 911 E. does anyone know if it will fit ? Thanks for the help !
Sounds like a 901 trans. I have that in a 911 and a 912. Dogleg 1st rules!
gearhead
Fits just fine. The 68 will be Alu and 69 mag but 911 vs 912 makes no difference.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Except for the Gearing
'68 is a short wheel base car. '69 LWB. I believe the axel flanges are different on the '69 transmission.
Tony
Tony 1973 914 2.2 FAT Black 1974 911 Targa Lime Green 2018 Macan GTS White 2019 Targa GTS Agate Grey |
I think the 912 had a different ring and pinion giving it a lower gear ratio.
Bob B. |
The chart here may be useful...
901 Series Porsche Transmission I have a 5 speed 912 in my Intermeccanica with a 2.4 911 S motor. Used a Fidenza light weight flywheel and a Kennedy Engineering custom made ring gear to adapt the two otherwise no problem. |
