-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Refurbished distrI but or for 912e possibly from Autozone? (http://forums.pelicanparts.com/porsche-912-technical-forum/896990-refurbished-distri-but-912e-possibly-autozone.html)
racerpaul 01-02-2016 07:05 AM
Got a tip that this refurbished unit might work on 912e engine? Any input?
A1 Cardone 31-915 Distributor | Frugal Mechanic
It's also available from Autozone
Jaems 01-02-2016 02:36 PM
It will depend on the advance curve. There are a few that will work some better than others.
Bob Ashlock 01-02-2016 06:47 PM
I bought one of these for my 912E about a year ago from Discount Auto Parts for $55. I verified the curve was correct and it runs great in the car. (The P.O. had installed an "009-knockoff" that was horrible.) I have seen some negative reviews about A-1 Cardone, but so far MY own experience has been good.
racerpaul 01-03-2016 05:55 AM
Thanks Bob, how did you go about verifying the advance curve?
Regards Paul
Bob Ashlock 01-04-2016 08:43 AM
At first, I used a timing light and monitored the advance degrees based on rpm from the car's tachometer. Later, I had access to a distributor machine (I was repairing it for a friend) so I stuck the distributor in it and verified it there.
andybullen 01-06-2016 08:12 AM
This is good to know.
Jerodhelt 01-14-2016 10:46 PM
Does anyone know where to get this distributor? Every place I've checked online is sold out...
Autozone lets you put it in you're cart, but when you try to checkout it says it's not available.
racerpaul 02-21-2016 01:28 PM
Core needed
Finally found out that Cardone has no stock or cores for rebuilding... not available anywhere as Cardone is the only source I know for rebuilding.
I will be contacting Cardone to see if they will rebuild mine if I sen them a core!
Will post result.
