-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   2056 CC rebuilt Type 4 motor (http://forums.pelicanparts.com/porsche-912-technical-forum/902382-2056-cc-rebuilt-type-4-motor.html)
Fixer 02-13-2016 06:15 PM
2056cc, 71 stroke, 96 bore, Standard low mile polished Crank , NOS main bearings
10:1 CR. Set up for Upright cooling only.
H beam rods, total seal rings, Web-cam(494), Scat lube a lobe lifters
JE lightweight wrist pins, Scat deep sump, 914 windage tray, Modified Berg
oil pump cover [has custom 125 psi relief valve built in], Modified Berg achiever pulley, Jaycee pushrods, solid rocker spacers, 1.7 rockers, chromoly rocker studs, dual valve springs and retainers, Manley spring cups, 44mm intake valves, 38mm exhaust valves, CB magnaspark ignition system, Treuhaft valve covers and intakes.
Estimted 140 - 150 HP with ample type 4 torque
Bench run for 30 minutes, built by 30-years experienced VW air cooled only professional Mechanic located in Va named Mark Wilson. I can provide his contact info.
Great motor but i may go a different direction.
$2000
Call or text Matt 267 767 4565http://forums.pelicanparts.com/uploa...1455416154.jpg
andybullen 03-01-2016 10:45 AM
Looks great - does it come with/utilize a 911 alt/fan set up or Joe Cali style?
roadsportusa 03-02-2016 10:32 AM
Hi Matt, Interested in engine. I live in New hope. Please call me.
Ron
cell 267-230-8579
Fixer 03-10-2016 05:31 PM
It sold for $3000 to a great guy up in NY.
