914 2.0 liter engine
My 912 is missing its engine and trans. Will a 914 2.0 liter engine and trans fit into a 912 engine bay?
I have a 1976 912E |
Yes but it will take some work. Go to this link. You will find several guys doing this conversion.
Chris 912 Renegades
1959 Auratium Green 356A Super w/ Rudge wheels 1970 Irish Green 914-6 w/2.2S Current -1967 Bahama Yellow 912 POLO 2cam4 #1 Handles like a 912 and goes like a 911 www.reSeeWorks.com |
gearhead
It mostly needs the tin and mount. They are basically the same engine.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Sounds like the OP already has a 912E.
Tony
Tony 1973 914 2.2 FAT Black 1974 911 Targa Lime Green 2018 Macan GTS White 2019 Targa GTS Agate Grey |
The 914 transaxel will not work in a 912E. Longer wheel base. plus the 914 transaxel drive is reversed due to it is behind the engine instead of in front. However it can be made to work in a 912.
I just sent you a PM regarding a 912E engine I have posted for sale over on the 912BBS forums. Unfortunately I sold the matching tranny a few years ago. The one you need is often referred to as a "923 tranny" which are the first 3 digits of the part numbers for parts unique to the 912E. They have become hard to find partially because they are also popular with the 911 guys who like to use their lower ratio differentials in their track cars.
Phil |
muffler
You are going to need heater boxes and a muffler if you use a 914 engine. The exhaust on a 914 it totally different than the 912E.
Bob B |
