Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 912 Technical Forum
cmpski's Avatar
This link says the E has a 3.5 bolt spacing. Basically a A caliper with the spacer removed. The calipers on this thread have a 3.0 bolt spacing. Actually you have quite a few more options than those of us who have struts and calipers with the 3.0 bolt spacing. Look into the non S black Aluminum Boxster calipers. I think they fit under 15 inch wheels. That should be a nice upgrade.
You might give Clint Smith at Rebel S Racing a call.
Chris
http://www.912bbs.org/vb/showthread.php?41703-912E-brakes&highlight=front+calipers
1959 Auratium Green 356A Super w/ Rudge wheels
1970 Irish Green 914-6 w/2.2S
Current -1967 Bahama Yellow 912 POLO 2cam4 #1
Handles like a 912 and goes like a 911
www.reSeeWorks.com
Old 04-27-2017, 01:55 PM
  Pelican Parts Technical Article Directory    Reply With Quote #41 (permalink)
Andy Bullen
andybullen's Avatar
Send a message via AIM to andybullen Send a message via Skype™ to andybullen
Super helpful - thank you!
76 912E - Grocery Getter
04 Toyota TacomaTRD - Beater Truck
08 Honda OdysseyEXL - Family Hauler
Old 05-04-2017, 07:53 AM
  Pelican Parts Technical Article Directory    Reply With Quote #42 (permalink)
I ended up using the banjo bolts from the old calipers. The guy I bought the calipers from gave me some curved line that fit almost perfectly. Ive only put about 30 miles on them so far. They still need to settle a bit, but as someone stated earlier, these will lock up and they do. Guess I need sportier tires
As for these fitting a 912E... I'm pretty sure those all came with 3.5" caliper mounts, so your option for upgrade are much greater.
1969 Porsche 912
2012 Mustang
Looking for Engine #4096213
Old 05-18-2017, 01:34 AM
  Pelican Parts Technical Article Directory    Reply With Quote #43 (permalink)
Is there anyone that produces a conversion/adapter bracket that replaces the original caliper brackets that use the 4 threaded bolt holes on the early 911/912 front struts and will allow the use of 3.5" spacing calipers?
Seems like it would be easy to make, basically a flat plate that would bolt to the spindle and have caliper mounting holes spaced at 3.5" instead of 3".
I'm doing an engine swap in my '66 912 and would really like to be able to upgrade to vented rotors and larger calipers without having to shell out crazy prices for later struts/arms/etc just to get the 3.5" caliper mount spacing.
Old 12-20-2017, 04:31 PM
  Pelican Parts Technical Article Directory    Reply With Quote #44 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
