Fuel tank leak-off pipe - where does the hose end?
Hi.
Can you also tell/show me where the hose from the fuel tank leak-off pipe ends? I is not clear to me
Palle
Old 03-01-2016, 02:46 PM
Hi - Again
Perhaps a simple question, yes - however, I simply need a photo showing how this plastic hose runs
Palle
Old 03-04-2016, 10:48 AM
I hope you are talking about the tank vent that also serves as a dump tube for brake fluid overflow (yellow Tygon tubing in first photo). Here's a couple of photos from my 68 coupe.
Plastic line goes through the sheet metal and behind the tank:
Exits out the pan just in front and inside front suspension crossmember mount (front suspension removed):
Peter
Old 03-04-2016, 01:24 PM
THANKS Peter
Old 03-05-2016, 04:23 AM
