Sputtering, gasping, coughing 912!
My 1969 912 when starting and for awhile after, coughs and spits from the drivers side carb. I hear this is a good sign I need to have the carbs rebuilt but I am wondering if there are any quick things that need to be done/checked first as a solution.
-gets better when warmed up and does not gasp when at driving RPMs
-idles pretty good even when cool
-the worst is when cool and around +/- 1000 RPMs
-no coughing from passengers side carb
Any ideas?
Thanks, Dave
Old 03-06-2016, 11:03 AM
Hi Dave
Question Are you using webers or solex? Have you done any work to the carbs resently? Has it ever ran right? A few things to check would be fuel pressure. Are you using a electric fuel pump or stock? Change fuel filter. Bad base gaskets may be leaking. Just a few thing to check.
Jerry
Jerry McAbee
1967 912
1968 912
2002 Tundra 4x4
Old 03-06-2016, 09:09 PM
I'll assume you've also properly adjusted your valves?
John Thompson
Eugene, Oregon
Old 03-07-2016, 06:27 PM
Hi dave
My '68 does something similar. Same pattern of worse when cold. Engine also quakes in range of 11 to 1500 rpm. Will be doing a tune up ex carbs and will update.
Dana
Old 03-14-2016, 10:10 AM
Start with what John says and work from there.
Scott
'78 SC mit Sportomatic - Sold
Old 03-28-2016, 02:50 PM
