2nd gear grinds
I have 67-912 coupe with original 5 speed transmission stock / When I drive and shift into second gear, the transmission grinds occasionally, not all the time, occasionally. When I shift I pause a second or so and put it in gear like I do the others. If I wanted to get that fixed so it does not grind, what are we talking about in $$$, assuming that it's just that gear. I know there are alot of others things to check and probably replace since we are opening Pandora's box. Looking for all input, good and bad and other things that I have not mentioned that need to be factored in.
Disclaimer: I don't have tools, the proper garage, time, etc to undertake this myself so I would have to source the project out. Gordon |
The synchro's are probably gone and need replacing. A complete rebuild of the transaxel would be about $2500. Or less if all it needs are the synchro's.
If you do the rebuilt. Just remember, never shift into 1st gear while the car is moving and the synchro's will last longer. |
