Help,My 912 Rear crankshaft seal has always oil leak..
Hi
Im Antony from Hungary, I have 912 from 66' All engine was rebuilt by my self. Sure,the rear crankshaft -fly wheel side-seal also we changed. If the engine running 5 min,the oil leak coming.. I to bougt in 4-time new seal,brown-black-blue..japan,Germanian,and hungarian produkt..better,stronger....but the oil just coming.. Perhaps,do you have any idea?...maybe need the bolt also change?...I have 3 size washer,the crankshaft not to move,I can adjustable. thx for any advice Antony Mann ![]()
Antony,
There are several things that come to mind as far as the leak:
Good looking motor!! Hope this helps! Peter |
Ok Peter,
I try it.. I to bought now the faoumus "Viton" seal..in my country the mentioned seal is cheap,cost is 10$ Thx Antony |
flywheel
Antony
The real problem is probably that the flywheel has a grove worn in it from the seal. Check the part of the flywheel that fits into the seal if there is a grove worn in it you need a replacement flywheel. You may be able to machine the flywheel and remove the groove ( if there is one ) but if you remove to much it will reduce the sealing surface to much and the seal will really not work. mike curnow |
Mike
Thx for your answer, and advice. The flywheel like a new, without any worn, "standart grosse". The problem is was joking:Bad oil! Actualy,I always usd 15W30.. Never problem with a rebuilt engine. All bearings, seals,etc...new. Now 5W-40...the problem resolve. Its crazy..
Email contact:Anthonyfromza@hotmail.com |
Antony,
I had a similar issue using 5W-40 synthetic. The issue was mostly resolved by changing to 20W-50 Valvoline VR-1, a petroleum-based oil ('dinosaur oil'). The VR-1 formulation has enough ZDDP to support 'flat tappet' motors (although US emissions is cracking down on ZDDP content). There are other dino oils with high ZDDP content (Motul, others). The trusted engine builders here recommend 20W-50 weight petroleum-based oil with higher ZDDP levels. I went through 4 oil seals on my current motor (built with parts from two motors, over 50K miles since August 2012) trying to solve the final small leak problem. ![]() I am currently rebuilding the original motor: Ol Smokey Rebuild. Both motors use Scat crankshafts which I hope is not the source of nagging main seal leaks... Peter |
Some thing like these wear sleeves could help
DuraSLEEVE Home: Shaft Sleeve : Hard Chrome Sleeve : Sleeve Vancouver : Shaft and Yoke : Dura Sleeve : Oil Seal : sleeve : Repair Sleeve
Joseph • 1967 Light Ivory 912 • |
