-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   912E question (http://forums.pelicanparts.com/porsche-912-technical-forum/91365-912e-question.html)
silver912e 12-18-2002 05:53 PM
912E question
I'm reassembling my 912E engine and forgot to mark
which cylinder gets the L-jet head temp sensor on it's
head.
Anybody know which one it is
Thanks.
Mike
thomasz 12-18-2002 06:19 PM
It's the "Temp sensor II"
Temperature sensor II is screwed into the front of the left-hand cylinder head above the combustion chamber of the No. 3 cylinder.
Nominal value at 20 degrees C / 68 degree F motor and ambient temperature: 1.5 to 2 K ohms.
When the motor temperature is above 80 degrees C / 176 degrees F the value must be less than 300 ohms.
Tom Zuraw
